Reboot Issue with Rampage V Extreme
benben09
Hi there,
I just finished my new build last weekend but got a frustrating problem every time I reboot my PC. The PC works fine each time I turn on the PC. I can see ROG boot screen before login into Windows. I can also type del or F2 to enter ROG BIOS. And after login, windows works fine as well.
However each time I restart from Windows or press the reboot button on the PC front panel, it fails everytime to boot. No ROG boot screen, and you can't enter into BIOS. Always black screen with a blinked cursor. The Qcode always stucks at AE and windows can't be loaded. But if I turn off the PC and turn it back on, the PC works again.
I have been updating all drivers and checking the connections but the problem still exists.
Any idea what went wrong? Much appreciated!
Motherboard: Asus Rampage V Extreme
CPU: Intel i7-5960X
CPU Cooler: Corsair H90
Memory: G.skill Rjpjaw4 F4-2400C15Q 8x8G
SSD: SAMSUNG 850 PRO 2x250G [ RAID 0 used as boot and OS partition ]
HHD: WD 1002FZEX-00Z3A0 [ DISK 1 ]
HHD: WD 4000F9YZ-09N20L0 [ Disk 2 ]
PSU: Seasonic M12 II Bronze 620W
Graphic Card: Asus GTX760
OS: Windows 8.1 Pro
BIOS version: 0706
Boot Order: option 1 - Windows boot manager (raid 0 partition); option 2 - DVD combo
Hi there,
Exactly same problem for me, when i reboot, nothing, screen is black.
Need to poweroff with button.
Then start again and no problem, windows start.
CPU: Intel i7-5930K
CPU Cooler: Corsair H110
Memory: G.skill Rjpjaw F4-3000C15-4GRR 8x4G
SSD: Asus Raidr (system)
SSD: 2X Samsung 840 evo 1to
HHD: 6X Western Digital 3To Red
PSU: Corsair ax1200i
Graphic Card: 2xMSI 4 Gaming GTX 980
OS: Windows 8.1 Pro
BIOS version: 0706
You should start your own thread.
BIOS upgrade to 802 solved my problems too.
I have no idea about the QCode (haven't got my cabinet open), but at reboot (not full shutdown/restart), one of two things would happen:
1) I'd enter UEFI BIOS. I'd have to shut down PC entirely and power on again to be able to boot.
2) ROG logo would appear, then black screen with blinking flat cursor at top left (char pos 0,0 in a 80x25 display). Cursor would then appear at approx char pos 10,6 for a few seconds, then back to 0,0 for a few seconds, then back to 10,6 and stuck there. Full power down to fix problem.
Motherboard: ASUS Rampage V Extreme
CPU: Intel Core i7 Extreme Edition 5960X
GFX: ASUS GTX980-4GD5 - 4 GB GDDR5
RAM: 8x4GB Corsair Vengeance LPX - DDR4 - 2666 MHz
Samsung 840 EVO 250GB SSD
Noctua NH-D15 CPU Cooler
XFX 750W xxx Edition PSU
Fractal Design Define XL R2 black cabinet
3 x Asus VN247H 23.6" monitors
Windows 8.1
I have had the same problem, I update the bios to 802 and the problem went away for 4 days and now its back. Any suggestions?
I have a similar problem with my Rampage V Extreme. I also have the Intel i7 5960X. My system is brand-new, just out-of-the-box. When I not been able to get past Q Code 76.
I went to the Asus downloads for my board and in a BIOS Flash update useing the "Intel 5th Gen" dated 04-26-2015. Can give any ideas.
Bob
