Archived from groups: alt.comp.hardware.homebuilt (More info?)
I did a "compromise" and instead of getting a new system from Dell, with
whom I've had a lot of bad dealings, I had one built for me by
www.endpcnoise.com aka NW Computers in Vancouver Washington.
It has an Asus P4C800-E Deluxe motherboard, a 3.2 cpu chip and 1024
Kingston memory (2 512 dimms). Ami bios. Came with Windows XP Pro
installed, along with Office SBE installed. Both are OEM versions.
It seemed to run fine but as time has gone one, and I've begun loading
all my software, I'm having occasions of sudden rebooting which has
already corrupted an Outlook file which was open at the time of one of
the reboots.
Here's the scenario:
I use a cable modem for internet access and therefore, didn't get to try
out the modem until I installed WinFax Pro 10. It sent faxes fine. But
- when I received a fax, the modem made a strange noise and the system
rebooted. This happened 3 or 4 times.
I switched out the inexpensive modem it came with and replaced it with
my old US Robotics from my other system. It worked fine - faxes
received and no more reboots.
Today I installed my USB Palm and the newest software downloaded from
their website (actually it's a Visor Prism using the Palm 3.5 OS). It
synced ok. I installed a program I've used before which syncs with a
database. I synced again and everything was fine
I tried to sync again a while later and right in the middle, the system
rebooted. This happened twice. I've now plugged in the USB cable to
another port and synced a few times without a problem.....
I'm very disturbed because of the rebooting, which of course, will
corrupt data and since I do a lot of multi-tasking, leaves me very
vulnerable to data loss.
Even if a program showed some incompatibility, or a hardware connection
is bad, why does the entire system reboot? I could see if it hung - but
rebooting is kind of serious and leaves one very vulnerable.
Is there something I should check? Where do I begin?
the reboots.
