I work on computers for a living, but this has me stumped. Having a random restarting, apparently due to memory dumps in Windows (according to event logs and dmp files), and I am completely unable to isolate anything as the culprit.
Whenever I'm playing a game (ie: CS:S, LOTRO, etc) I get random mem dumps. The machine freezes for a second or two, clicks, then just blanks out and reboots. It may not do it for 2 or 3 hours, then all of the sudden hiccup. Usually after the first time, it does it again shortly after. This happens repeatedly.
I've run a crapload of hardware diagnostics multiple times and have had zero failures. Suspected RAM first, ran Memtest86 a few times, including about 10hrs straight yesterday (32 passes) and no problems. Even brought home a new pair of 512's to test and it still acted up. So that pretty much rules the RAM out.
I ran a couple video RAM tests that all passed, and 3DMark 05 -and- 06 both ran through the basic test fine. I had the issue with both my old PSU and my new 430W Thermaltake. HDD tests out fine for read/write/stress. CPU stress tests fine. It's definitely not a heat issue. I have no frickin clue whats left.
I'm beginning to suspect the motherboard. Does this seem like the only remaining possibility? If so, I'm about to just upgrade mobo/CPU/RAM anyway. Any suggestions or advice appreciated. TIA
