So the story is that I own a caravan at a caravan site where there is free Wi-Fi. The wi-fi is set up with mesh transmitters and slow each user limitation of 15mbps.
My caravan is sitting at the far side of the wi-fi transmitters. When I am outdoors I get a OK signal, but inside my caravan with all the metal I get no signal.
I initially solved the issue with this repeater
https://www.ebay.co.uk/itm/163517345611
I mounted it on my caravan roof witch has a direct line of sight to the wi-fi transmitter. It retransmitted a strong WiFi signal with my own password protected SSID. When I spoke to the caravan site networking admins they could however tell me that the repeater is creating interference and is making the bandwidth worse for other neighbors. After reading a bit on the issue it seems true that repeaters create interference.
So my goal is to receive the wi-fi signal inside my unit but without the use of a repeater that creates interference at the same time. Anybody have any good ideas of what equipment to procure?
One solution im thinking of, is to use a old router with DD-WRT firmware to get WiFi to wired internet. This router will have external antenna on top of my unit. from the lan port of this router I will use another router to create a small wireless inside my unit, set it up with a channel far from the site wireless and hopefully end up with stable WiFi inside my unit. Any thoughts?
Thanx.
Cato.
Thanx.
Cato.
