[SOLVED] Recent SSD Problem IO operation
mudum123
Commendable
Mar 6, 2021
This is happening recently. The problem on event viewer before my computer is freezing is "The IO operation at logical block address for Disk 0 was retried". Lots of logs like this.
I'm not sure if this is more frequent when I'm playing a game since this usually when it happens. Not sure how this affects it though since all my games are on another M2 just bought 2 months ago
I have tried chkdsk, sfcscannow, crystaldiskinfo, samsung magician and they're all good/healthy. I don't think it's also a cable problem since this started 2 weeks earlier (tried replugging cables, havent tested on new ones yet).Also I did upgrade my AMD BIOS and chipsets recently, MPG-X570-GAMING-EDGE-WIFI with the latest Resizable BAR.
Mind you this is a 3-4 year old 250GB Samsung 850 EVO. This could just be on its last legs.
A system administrator who encounters event 153 errors should investigate the health of the computer’s disk subsystem. Although an occasional timeout may be part of the normal operation of a system, the frequent need to retry requests indicates a performance issue with the storage that should be corrected.
https://docs.microsoft.com/en-au/archive/blogs/ntdebugging/interpreting-event-153-errors
SSD don't give any warnings so if you suspect drive might be on last legs, get a new one and replace it. Use it as storage of non essential data.
I would use the 500gb nvme as boot drive (I actually was going to do just that but got 1tb nvme instead). I don't know if its the nvme or the 3600XT but my boot is pretty much instant...
What are specs of the PC?
can you give me the event number?
My PC Specs is:
MPG-X570-GAMING-EDGE-WIFI Mobo
Ryzen 7 3700x
16 GB RAM TFORCE 3600mhz
Nvidia RTX 3080
1 250GB Samsung 850 EVO. (OS drive)
1 500 GB Samsung 970 EVO m2
1 TB HDD
Here is the whole XML:
- <Event xmlns=" ">
- <System>
<Provider Name="disk" />
<EventID Qualifiers="32772">153</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-03-06T13:47:31.4137968Z" />
<EventRecordID>60004</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="3196" />
<Channel>System</Channel>
<Computer>Jan-PC</Computer>
<Security />
</System>
- <EventData>
<Data>\Device\Harddisk0\DR0</Data>
<Data>0x199b89a0</Data>
<Data>0</Data>
<Data>\Device\0000003a</Data>
<Binary>0F01040004002C0000000000990004800000000000000000000000000000000000000000000000000000042A</Binary>
</EventData>
</Event>
I would use the 500gb nvme as boot drive (I actually was going to do just that but got 1tb nvme instead). I don't know if its the nvme or the 3600XT but my boot is pretty much instant, once bios gives windows access. I had an 250gb Evo 850 on last PC and it took longer to boot up.
