Recently Built Computer USB slots dont work?
alurousaac
51
5
10,535
Hello, I recently built my computer on a MSi Z370 sli plua MoBo, and the usb slots are occupied with a Razer keyboard, mouse and headphones.
1, the razer peripherals are glowing and I am typing on the keyboard and using the mouse.
2. synapse doesn't seem to read/show any of the three peripherals on it's list.
3, all flash drives I am trying to connect, on the case itself, and on the keyboard that has a usb slot, none seem to be readable.
so my issue is that even though the peripherals seem to work, I cannot see them in synapse, and I cannot make the PC read any Pen drives.
I installed all the MoBo Drivers from the disc it came on, Im not sure if I have to install additional stuff.
any ideas?
Did you do a clean install? The drivers etc on the MSI site maybe more recent than whatever is on the cd/dvd
I wouldnt installer super charger. if it's as bad a ASUS Aicharger and Gigabyte On/Off,it'll crash the system sooner or later
I wouldnt install Intel Extreme Tuning either
If it's brand new just installed system it's a bit troubling. I assume you did not touch any usb related setting s in bios or power management? If you're using windows download and install all updates and reinstall/update drivers from the msi site for your motherboard:
http://
Some of them are probably updated already since I saw few with 29.12 date.
