Here is the build I put together ~ 2 weeks ago.
http://pcpartpicker.com/user/Shiftymnm/saved/1sP1
Basically, since I first assembled it, I had these random entire computer "lag" problems. During this time, my mouse would start lagging and jumping instead of moving fluidly, I would disconnect from the internet, and my CPU load %'s would start jumping all over the place from 0-50%. I always check windows task manager when it happens but I never notice anything that stands out.
The weird thing is I don't know what causes the problem to start. It has happened to me before when I would just turn the computer on and go to a webpage and it would start. Other times, it will hit me in the middle of a video game. I use this computer to stream and I have successfully streamed while gaming with this issue never ocurring. During the stream, my CPU temps and load %'s were as high as I have seen them, around 60 degrees C, so I don't believe my CPU overheating is causing the problem but I really have no idea. I also monitor my GPU and it never gets above 80 degrees C which as far as I have read is average.
If anyone could help at all I would be so grateful. If you need more info from me let me know. Thanks in advance.
