Hi there!
I recently repasted with using the Grizzly Liquid Conductonaut and i started to see some slight decrease in temps. My usual idle temp was 45 degrees and it dropped to 40. My temp was around 78-85 degree(barely hits 90) when gaming while before it was around mid 80 degrees and occasionally hitting 90 degrees. I expected a much lower temp drop but i was contented with what i had. However after a few days I noticed my temps increased to 50-60 degrees when idle (constantly increasing and decreasing) and when gaming my temps hit a avg of 90 degrees. Im not sure what caused the problem but i suspect the liquid metal may have spreaded as i did took my laptop to another country (there was alot of movement). I need a solution ASAP. My laptop is the acer nitro 5.
Thanks in advance!
Heres some pic (I dont know which is the cpu and gpu)
https://share.icloud.com/photos/0zTrC67rYBxRZPsEVGpAn_J1g#Taman_Universiti,_Johore
https://share.icloud.com/photos/0Ahk3jV7dnOWFQj2WX39K0TsA#Taman_Universiti,_Johore
I do not get it. I just ran a CPU stress test and it is averaging 65 degrees. I need answers
Thanks in advance!
