Question Recommend a specific high quality UPS for my system
Locko
12
MotherboardAsus TUF Gaming B550-PRO
CPUAMD Ryzen 9 5900x
RAM2x16 Corsair Vengeance LPX DDR4 32GB 3200MHz CL16 (CMK32GX4M2B3200C16)
SSD 1Samsung SSD 990 Pro with Heatsink 4 Tb
SSD 2Samsung SSD 970 EVO Plus 1 Tb
GPUAsus ROG Strix RTX 3080 Ti
Power SupplyFSP Hydro Ti Pro 1000W
Processor CoolingBe quiet! Dark Rock Pro 5
CaseBe quiet! Pure Base 500
Case fan 1 (front)3 x Be quiet! SILENT WINGS 4 120mm PWM high-speed
Case fan 2 (back)Noctua NF-A14 industrialPPC-3000 PWM 140mm
Case fan 3 (top)2 x Be quiet! Pure Wings 2 140mm
Brand is going to mostly depend on where you live and availability. As long as you stay away from junk shipped directly out of china you should be ok.
What you are looking for is a UPS that can deliver the full 1000 watts your power supply might pull. Likely it never get that high but if you were to exceed it the protection circuits in a UPS would turn off the power as if you unplugged it suddenly.
Be careful VA and watts are related but not the same read the fine print and look for how many watts it will provide.
My guess is you are going to be looking at a 1500va unit.
The key feature you want that will make it more expensive is you want sine wave...not simulate sine wave. Modern computer power supplies are very sensitive to poor power. If money is really tight it is important to remember that you are only running on this simulated sine wave when you are running on the battery. Depending on how often you lose the power it likely is only a small number of minutes a year.
Reactions: Locko
