CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor
Motherboard: Gigabyte - GA-Z270X-Ultra Gaming ATX LGA1151 Motherboard
RAM: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
SSD: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
HDD: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card
CASE: Corsair - 760T White V2 ATX Full Tower Case
PSU: EVGA - SuperNOVA G2 850W 80+ Gold Certified Fully-Modular ATX Power Supply
Need the best possible CPU Cooler that's air cause I don't want to risk leakage. THAT WILL FIT. I have no idea if a cyrorig will fit on this etc.
I don't really have a budget for a CPU cooler. Just make it around 100 usd or less 😛
Will OC and I will be streaming on this so the temperatures matter a lot. The case stock fans should be enough right? This case comes with lots of fans so..
I made the same mistake with cooling on the first PC build im using now. I won't go lightly on cooling. It's bullshit when people say u dont need good cooling if u dont plan to OC.. Cause you do.
Thanks 😀
I also don't know how to mod the cooler to make it fit and shit.. So like yeah. if i need to trim something (just an example) tell me when recommending the cooler. thanks.
Thanks 😀
