Recommend PSU for heavy RGB Build?
Hi all,
I'm not very experienced when picking power supplies. I am looking at these 3 choices:
- EVGA 650BQ
- Corsair CX650M
- Seasonic M12II 620w Evo Edition
- BeQuiet! Straight Power E10/Pure Power 10 600w
Full Build and Parts:
- R7 2700X
- ASUS ROG Strix B450f Gaming
- GTX 1060 6Gb
- G.Skill Trident Z RGB 2x8Gb 3200Mhz
- NZXT Kraken M22
- NZXT AER RGB 120mm Fans (5 units)
- NZXT Hue+ (with 4 LED Strips)
- 1 TB SSD
- 4 TB HDD 7,200rpm (2 units)
- Fractal Design Meshify C
- Gaming Mice and Keyboard (full RGB)
- Arctis Pro Headset (LED)
- External Mic, Webcam, Wi-Fi Dongle with an LED
- 2 Phones almost constantly charging
Estimated use:
- 45 Hours of Video but mostly Photo Editing per week
- 30 Hours of Gaming per week.
It's got a lot of lights in there so I'm wondering if these PSUs are a good choice?
The Seasonic Focus is probably a bit more then the 4 your listed however remember that your PSU is the heart of your system and you don't want some low quality unit ruining your system.
Between the 4 your posted above I'd go with the CX650M.
LED lighting takes near to nothing to power, so probably wouldn't put too much concern towards that.
I have used Corsair as replacement and spec'ed equipment for builds for YEARS. I have never had a single issue with one, even on the budget level. Given the video card you are using you could go with less, but for price point to power I would stick around that 600w level anyway. Considering the price and rebate going with Corsair on and off you are likely getting it for around $35 anyway....I say go for it.
