Question Recommend RGB case fans for my build ?
May 2, 2023
4
Hello, I need the help please. Can somebody recommend RGB case fans with remote header and power supply that I can use without connecting to PC. I’m building a laser enclosure, and I need intake ventilation. Thank you in advance.
Where are you located? What is your preferred site for purchase and how much are you willing to spend on your fan purchase? Your case isn't off the shelf, now, is it?
hi, thank you for your reply. Amazon.ca. Or any North American site. I’m looking to buy two sets of three good quality RGB fans with the highest possible airflow. Of course, they will have to be with a remote control hub and standalone power supply. I kept buying cheap RGB fans and testing them. I burn so many of them :) that’s why I’m desperate for help, when I buy good ones, I don’t wanna ruin them too. Any help it’s appreciated towards right equipment and proper wiring installation. Thank you.
