Recommend vid capture card w firewire, rca, and svideo?
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I am looking for a video capture card that has firewire, rca, and s-video
input. I don't *really* want to buy separate cards for everything and an
all-in-one like that would work great. I am just not sure in which
direction to go.
Any ideas would be greatly appreciated!
thanks in advance,
Bill
>direction to go.
Check eBay for a used Pinnacle Dv500
BUT... You should FIRST go to the Dv500 forum and check to make sure
your motherboard is compatible
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=4&SectionID=12&ProductID=321&SubDocTypesID=96
John Thomas Smith
http://www.direct2usales.com
http://www.pacifier.com/~jtsmith
It doesn't look like it is widely accepted by many of the new software
programs, which is going to prevent me jumping on it - though it is exactly
what I am looking for though.
Are there any other products similar to that one that are currently
available?
thanks!
Bill
"John Thomas Smith" <jtsmith@pacifier.com> wrote in message
news:i9fi801pk5vl27i0po945tjttalmie0bt3@4ax.com...
> >direction to go.
> John Thomas Smith
Archived from groups: rec.video.desktop,rec.video (More info?)
Check out the Canopus ACEDVio card
One card for all Video Editors! ACEDVio is the world's only analog and
DV editing card that is completely compatible with hundreds of video
editing applications and all widely used video equipment.
Provides analog and DV input/output compatibility for leading editing
and DVD authoring applications.
Connects to all widely used analog and DV cameras and decks.
Compatible with Windows and Mac OS computers.
Provides the industry's highest quality analog-to-DV and DV-to-analog
video conversion with locked audio support.
Provides video output to a monitor or television while editing.
Features adjustable brightness, contrast, saturation, hue and
sharpness controls on analog video input*.
The broadest editing software support and video equipment
compatibility ensures a longer product life and a high return on
investment.
ACEDVio is available in several flavors:
ACEDVio Ultra Bundle $549.95
Combines Canopus's ACEDVio realtime analog and DV capture and output
solution with Adobe® Premiere® Pro, Adobe Audition™ and Adobe Encore™
DVD.
ACEDVIO w/ Vegas 4 $499.95
ACEDVIO (card only) $299.95
For more info or to order http://www.videoguys.com/ACEDVio.html
Gary
Videoguys.com
The Electronic Mailbox 800 323-2325
We are the Desk Top Video Editing and DVD Production Experts!
Sign up for the Videoguys' Insider newsletter http://www.videoguys.com/insider.html
