Question Recommendation ATX case under $90?
BrainY
393
A friend offered me an i7 13700k, a mobo, an cpu air cooler, 2*32gb Ram, and a 850w power supply. Instead of taking everything out of my Fractal Design Define case, I want to buy a new case and just add my existing m2 drive, sata ssd, and 6700XT GPU (with a fresh W11 install)
Any recommendations for an ATX case less than $90?
I do not care much about cosmetics, I care more about performance. I do not overclock as of right now.
I was looking at the following...
Lian Li Lancool 207 ($75)
Montech Air 903 Base ($65)
Montech Air 903 Max ($85)
Fractal Design Pop Air ($80)
You might want to reconsider using the 13th Gen Intel platform due to concerns of oxidation/degradation issues. You've also generically stated the motherboard, cooler ram and PSU, please add their makes and models. Include the age of the PSU as well.
If I were buying into any of the 4 I'd get the Lian-Li Lancool 207 however to clarify, cases are supposed to be personal preference. Either of those cases are great in terms of thermals.
