Recommendation for 80mm case fans
Jacob_107
190
Hey there, I would like to ask whether anyone could recommend any good quality but also not too expensive case fans. I would prefer white or transparent colour to match my case and the whole setup but it is quite difficult to find some good ones as 80% of the fans are painted black. To be more specific I'm looking for two 80mm case fans to improve the overall airflow within my case. I currently own the Thermaltake Core V1 case which has a 200mm front fan which takes the air in and I thought that it would be useful if I could have two fans sucking the air out so less dust would build up and the airflow would be improved, therefore, cooling would be more efficient as well even if it wouldn't make a significant difference to the temperatures.
What I found: https://www.maplin.co.uk/p/cooler-master-bc-series-80mm-blue-led-fan-a12nn
I found those case fans from Maplin for a really good price which come with LEDs as well even if I wouldn't really need them but the product isn't available at my location and neither for delivery and probably is priced this low in order to clear out the stock. Would appreciate links. Thank you for your time.
