Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
It will fit on an Abit NF7-s 2.0 if you cut the clip
iam going to
put the 7000a Cu on mine
I sent an email to Zalman asking them to cut a clip and send it to me
maybe they will do it for me
On Thu, 22 Jul 2004 23:31:18 +0100, "Shawk"
<shawk@clara.co.uk.3guesses> wrote:
>"tomcas" <tomcas@NOSPAMmjwebsitedesign.com> wrote in message
>news:RWWLc.16839$YQ6.1744549@news4.srv.hcvlny.cv.net...
>> Shawk wrote:
>> > "Al" <A@nospam.net> wrote in message
>news:410007a7.1722739@news.mr.net...
>> >>On Thu, 22 Jul 2004 18:21:18 +0100, "Shawk"
>> >>Here is an example of what makes a good, quiet fan:
>http://www.newegg.com/app/viewProductdesc.asp?description=35-150-010&depa=0
>> >>For quietness use the largest heatsink possible for your MB combined
>> >>with the largest fan size. This will allow it to run at a lower RPM
>> >>and get the same cooling. Always look for ball bearing fans.
>> >>This is running at the very low end with 2700 RPM and a noise level of
>> >>26.5 dBA. If you use processor intensive apps then a 3600 RPM fan with
>> >>about 30 dBA would keep it cooler.
>> >>>For an AMD XP2800+. The stock is now the loudest thing in this case.
>> >>>Many thanks, appreciate it. Shaun
>> > Found a stockist of the WhisperRock in the UK - only £7. Now I just
>need to
>> > find out whether its OK with my mobo.
>> > Thanks, Shaun
>> > Abit NF7-S(2) Mobo
>> > AMD XP2800+
>> > Antec 430W true Power PSU
>> > Sapphire 9600 Pro (soon to be 128MB, 256bit 9800 Pro)
>> > Antec 1080AMG case
>> copied from Newegg reviews of Speeze "WhisperRock II" CPU Cooler, for
>> AMD/ Intel Socket A/ 370, Model "5F263B1M3G"
>> Model# 5F263B1M3
>> Item # N82E16835150010
>> It apparently fits your mobo.
>> "Dave,3/6/2004 11:12:14 AM
>> CPU: AMD Athlon XP 2500+
>> Mobo: Abit's NF7-S
>> Idle Temp: 37 C
>> Full Load Temp: 45 C*
>> Installation: Simple to install, also used the paste that came already
>> applied.
>> Noise: Can't hear it over the noisy fans that came with my case.
>> *Temperatures may be a little higher then they could be because of the
>> bad airflow in my case."
>Cheers, appreciate it. Shaun
