Recommendation request for PC parts
Arjesh
24
Hello there,
I'm thinking of upgrading my PC further very soon but I'm confused on which part to upgrade, my graphics card (AMD R390) to GTX1080, or my CPU (i5 4760K) to i7 4790K or the new SkyLake series.
Your advice is appreciated
Here are my specs btw:
CPU: Intel Core i5-4670K @4.1Ghz
Cooler Master 120XL Liquid Cooler
PSU: Cooler Master 750w
RAM: G.Skill Ripjaws 1833Hz 16GB
GPU: MSI Gaming 390 8GB
Motherboard: Asus Z-97 Gamer PRO
Tower: Cooler Master Sniper Black Edition
Mouse: Mad Catz R.A.T Cyborg 7
Keyboard: Logitech
Monitor: Asus VG248QE 144Hz
Samsung EVO 840 - 120GB SSD
Seagate Barracuda 2TB Internal HDD
+250GB Internal HDD
+500GB External HDD
+1TB External HDD
Thanks in advance.
I would start with the high step up in GPU and see if that satisfies your performance expectations.
An i7 (and 4790k is almost equal to a 6700K, so no need to spend extra on a platform change while 4790K's can still be had in the stores) can be be helpful for multitasking & gaming, like recording and streaming, or playing those big 64player/big map MMOs.
If that doesn't apply to you though, you may not miss that performance potential.
The only reason I thought of upgrading the CPU is because I'm getting some irritating frame-drops on some games, not because I'm not getting enough frames. On a side note, I'm also thinking of streaming soon.
What do you think?
So, getting frame-drops on some games should not be a reason to upgrade the CPU?
Streaming can certainly be one of those things where the i7 is tremendously helpful, but it depends on the game (its CPU usage) and the other things you're doing in the background that compete for resources. The old adage of 'few games take advantage of more than four cores/threads' is certainly true, but if you do have a game that's taxing the full 4c/4t system, that leaves little room for multitasking (again, recognizing that an i5 is a great 'gaming CPU').
The symptom you're experiencing though may be do to other things.....hard to say from the brief description. Display/GPU adaptive sync (or not syncing, using vSync, etc) can also produce visual artifacts, and this could be what you're perceiving.
Thanks for everything, I think I'll upgrade my current graphics card to GTX1080 (unless AMD actually releases something competitive).
Ciao
Well, thanks Mr. Moderator, I've made up my mind and decided to upgrade the graphics card.
I will not, however, exclude the idea of upgrading my CPU as well only if AMD's Zen is as promising as they're advertising it.
Regards
Could you state which games you see these frame drops in?
So late for the response I'm terribly sorry, but the issue still stands. I'm getting drops in Black Ops 3, and sometimes in The Division. Of course all while I'm recording my gameplays
