Is there a USB Hub that hangs off a Type C or other super-speed port, that provides at least 8 super-speed Type A connections that RUNS COOL???
I noticed the USB Hub recommendation that TH posted for Sabrent, but did not specifically note anything about heat. I currently have a Latorice hub with 10 data ports and 3 charging ports that I want to stop using because of its excessive heat. I DO NOT use it for charging and don't have the external power supply connected, but it runs very, very hot with or without the external power supply. I know heat degrades flash drives over time and that is mainly what I use a hub for, long-term flash storage on multiple large thumb drives.
