Over the last few years I've gone through a dozen Corsair Coolers, mostly H115i's that keep failing. Also, they don't cope in the Aussie summer. With ambient temps over 30c the cooler is pretty much ineffective with coolant temps hitting 40c and fans spinning at 100% as CPU temps sky rocket.
I have few needs. (1). I don't care about RGB only performance. (2). I want to be able to tweak fan curves and view temps and speeds from within Windows. (3). Any software should not be bloatware riddled with telemetry that thrashes my SSD/HDD and needs 900Mb to install (CAM/iCue, I'm looking at you!)
Fan connectors should be standard 4 pin PWM.
I'm suspecting it's time to venture into custom loops?
I've read reviews for many coolers, many of which contradict each other (Like one review will say cooler A is awesome while another review will say cooler A is the bottom on the barrel). Kinda makes it hard to know who to trust and which cooler to buy.
I'm looking at cooling two HEDT systems, mildly over clocked. One is a Thermaltake W100 case. Lot's of Room. The other is a Fractal Design 7 XL. The W100 has 11 case fans. The FD7 has 4.
I'm pretty much 100% against NZXT. The cooler may be good but Cam is a disaster. I believe you can't even run CAM now unless it can go online, which I won't allow.
I can put a 360mm in the W100, maybe even a 420mm.
But realistically, what's the best delta I can expect? If the ambient is 30c am I just expecting too much to have a 4c delta? And when the ambient hits 35c or higher is the cooler going to cool at all? Like, if the coolant is at 40c (eg), then I'll probably have fans running at 100%... Does that leave the cooler with nowhere to go... no ability to cool?
I've been struggling with this for years trying to keep my PCs cool over summer. I've even backed off OC's to help.
Would appreciate some advice. If you recommend something, price is low on my priority list. Performance is top.
