I have an exhaust fan at the top left and an (intake?) fan at the bottom right, both came with this case , my friend's old midgar xigmatek case:
https://www.techpowerup.com/review/xigmatek-midgard/3.html
Have put the psu in with the fan at the bottom, I also have bought 5 of these :https://www.amazon.co.uk/dp/B07HC7P3HJ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
which are OPTIMISED FOR STATIC PRESSURE. I have the Thermalright Phantom Spirit 120 EVO CPU Cooler, a 14600kf cpu and the Asus PRIME B760-PLUS motherboard.
There seem to be space for a fan on each side of the cover, two more at the top and one more at the bottom. Wondering how many more should I put in after the first 2? it seems that the cpu can get pretty hot, my cooler is middling, and due to the mobo not being the best quality I should install more?
However I only have 1 fan (headers) left after accounting for the 2 slots taken by the cooler fans and the 2 already installed! Btw I have the cooler fans orientated in the same direction, I did it correctly , right? Also what are the other 2 connectors per fan for here please? The manual says something about sycing fan spped in a dual setup, no idea what this means, thought the system always speeds fans up based on need and I didnt need to make any extra connections.
Thanks for reading, sorry for the length.
View: https://imgur.com/a/ujDKPXS
