[SOLVED] Recommended 1080p monitor for enjoy PS5 120fps
james_911
6
Hi, I would like to replace my old screen with a new fullHD to use and enjoy the PS5's 120fps. Advice on the best models 27/28 " with 144Hz or more??
Thank you.
1080p, dozens to choose from. ASUS TUF series is what I have been recommending for budget gamers. A decent panel and okay everything else. LG and MSI have some offerings in that range as well.
165hz https://pcpartpicker.com/product/BK7p99/asus-tuf-gaming-vg27vq-270-1920x1080-165-hz-monitor-vg27vq
165hz https://pcpartpicker.com/product/Md...r-270-1920x1080-165-hz-monitor-optix-mag272cr
240hz https://pcpartpicker.com/product/jFxbt6/lg-27gn750-b-270-1920x1080-240-hz-monitor-27gn750-b
280hz https://pcpartpicker.com/product/JgCFf7/asus-tuf-gaming-vg279qm-270-1920x1080-280-hz-monitor-vg279qm
PS5 supports 4K 120hz, you could get that depending on what you want to spend...
Thanks for the answer, I'm checking the links, but sorry that I don't specify: the monitor shouldn't be curved because I don't like thats.
Is the 240/280Hz choice worth it? The ps5 max fps should be 120 and the double is not "too much"?
The last version should be perfect, but now the price of the 4K/144Hz monitor, in my country, is the double of the consolle value, I will look for somethins like that in the future.
Well, depends on what else you use the monitor for. I tend to keep monitors for many years, so buying a little ahead doesn't hurt.
Not actually sure on the max FPS of the console. HDMI 2.0/2.1 allows for 1080p 240hz, so technically possible. Any monitor you look at, just check for HDMI 2.0, which I hate to say is usually one of the harder things to find out. Not sure why monitor specifications are so poor, usually quite hard to find out.
I will use that only to play fps game with PS5/PS4. For the other games I have a 4K OLED TV.
Not all the reviews specifie the options of compatibility and I'm searching from some days, so only a list of monitor compatible with the 120Hz option of the console PS5 would be great 👍
