Recommended case fan speed inside speed fan
Tony1337
112
Need a little help with what should my case fan speeds should be i got phanteks enthoo luxe with a 200mm fan on the front as intake one 120mm on my storage drives to cool them and too push air though the cages and to my video card 120mm and 140mm fans on the case floor as intake got the first fan slot on the top of the case occupied by a 149mm fan and behind in the other 2 fan slots its a rad for my liquid cooled pc with 4 fans on a push pull set up and a 120mm fan on the back of the case for exhaust. thanks fot the read and please leave any fan perentage speeds that i should try out thanks!
I have setup a speed curve on SpeedFan to go max speeds when the GPU goes past 50 degrees because that's usually when I'm gaming with a headset but I have mine about 50%. Here is a screenshot of mine:
- Sam
