Recommended cpu cooler for my FX6300 on Antec 200 case
anyell1968
7
Hey guys, I just got my new cpu. but sadly the cm hyper 212x wont fit on my antec 200 case. Would you guys please recommend good cpu cooler that will fit on my case? please thanks!
Dam... the easiest case that is mounted differently by the the inside of the case that I know of would be coolermaster TX3. It is mounted in the inside of the case and doesn't need a backplate. It is 135 mm long.
