Recommended Graphics Card for VR Ready/General Gaming
8
In advance, thank you for any help!
I’m getting a Rift and also need to upgrade my graphics card. What card would offer the best value/longevity?
Budget: $500 ($550 absolute maximum if really worth it)
Current Card: Nvidia GTX 660
Processor: i7-3770 @ 3.4GHz
RAM: 10gb
Motherboard: Pegatron 2AD5
OS: Win 10 Pro
USB: 2x 3.0 and 4x 2.0
Monitor: Dell U2412M
If you’d recommend any other upgrades, I’m open to hearing those too…can add to my shopping list for down the road.
The GTX 1070 can handle the Rift resolution (1080 by 1200 pixels per eye).
With your new budget update, you could get the GTX 1080, which could handle higher resolutions in case you decide to upgrade your VR device.
Your CPU and RAM might prevent you from unleashing the performance of this GPU.
Thanks for the fast response! I just updated my budget. Would you still recommend the 1070 at the new budget?
I uninstalled my 660 driver software and then installed the 1080 yesterday. I successfully pass Steam and Rift's VR tests. However, I can't say that I see a visual difference. Is it possible that my monitor is outdated? I have a Dell U2412. Or could it be something else? I haven't tried with the Rift yet (arrives today), so this is just based on the monitor.
I'm also using about 80% of RAM with some games. In that case, would you recommend that I proceed with that 16gb upgrade?
Oh good! If I upgrade, I'll go 16gb max at this point and save up for a new system next. I'll have to check those games out when I get the Rift installed. Thank you! :)
Did you increase the eye candy in your games? That’s the only thing that’ll make a new gpu look better on the same monitor. If you were already at high, ultra might not look a ton better, depending on game.
If you are short on usb ports for the Rift, I’ve had good luck with this pci card:
https://www.amazon.com/Inateck-Express-15-Pin-Connector-KT5001/dp/B00FPIMJEW
Also want to spread the sensors across usb controllers to keep from overloading them.
Finally, probably need 2-3 meter usb and hdmi extensions.
