Recommended Overclock for i5 4670k with Noctua NH-D14?
Joey Martin
37
Hey everyone,
So i've never overclocked before and plan on getting the i5 4670k and using the Noctua NH-D14 CPU Cooler. What would be the highest, but still safe, overclock speed I could run it at?
Links:
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Overall System: http://pcpartpicker.com/user/SkyMysteryBlade/saved/2Q4s
Also, would there be a next step up CPU within like $50ish that would be better? Same goes for the CPU Cooler.
Thanks!
You'll probably get a stable 4,1-4,2 Ghz at 80-85C when running Prime95 for some hours. With the fans on max.
Though, there is little point in overclocking unless you need the extra performance. What do you plan on using your computer for?
With that said, you might win the silicon lottery and get an amazing Haswell that can be overclocked to 4,5 Ghz on air. But the chance is so small I wouldn't even think of it.
I would be using this build for Gaming.
Goodie.
Well I said 4,1-4,2Ghz@80C, the guy above said he got 4,4Ghz@95C.
That's the best I can summon for ya. Expect at least 4,1-4,2Ghz, and if you're lucky the silicon lottery might give you a chip that goes to 4,4-4,5Ghz on air cooling.
That cooler is quite expensive. You could choose to bump up to a Corsair H100i. With that you would have no problems bringing the CPU to 4,5Ghz at nice temps.
