I’ve thought about getting this power supply for my build, I have the parts above and also 8gbs of ram, looking to overclock as well, this is the psu I was talking about https://www.pcgarage.ro/surse/evga/bq-80-plus-bronze-650w/ thank you in advance
At stock settings your system will use less than 300W. Will probably be close to 250W while gaming. You said you want to OC and that makes a lot of uncertainty. Mild OC will probably reach the 300W area, while heavy OC on both the CPU and GPU could hit even more. I don't think you'd cross 400W OCing both however.
I agree that the unit you linked is a bit weak. More so if you are planning on OCing right off the bat. The 550W seasonic that was linked would be fine.
