Hey all I'm in the process of building a new computer and was wondering which power supply is recommended, here is the build parts:
-Processor: Intel Core i7-4790K: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819117369&cm_re=i7_4790k-_-19-117-369-_-Product
-Video card: MSI GTX 980 GAMING 4G GeForce GTX 980: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127834&cm_re=gtx_980_msi-_-14-127-834-_-Product
-Case: Rosewill BLACKHAWK Gaming ATX Mid Tower: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811147107&cm_re=rosewell_blackhawk-_-11-147-107-_-Product
-Motherboard: ASUS Z97-PRO LGA 1150: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132116&cm_re=asus_z97_pro-_-13-132-116-_-Product
-RAM: HyperX Fury Black Series 16GB (2 x 8GB) (buying 2 sets for a total of 32GB of RAM): http://www.newegg.ca/Product/Product.aspx?Item=N82E16820104445&cm_re=HX316C10FBK2-_-20-104-445-_-Product
-SSD: SAMSUNG 850 Pro Series 256GB: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820147360&cm_re=samsung_256gb_ssd_pro-_-20-147-360-_-Product
-HDD: Western Digital WD Green 2TB: http://www.newegg.ca/Product/Product.aspx?Item=N82E16822236404&cm_re=western_digital_green_2tb-_-22-236-404-_-Product
This is the final build, no additional parts will be added in the future. I was thinking for the PSU: CORSAIR HX Series HX850 850W: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139011
Is that overkill? There also seems to be different ratings, 80 Plus Platinum, 80 Plus Gold, 80 Plus Bronze, etc. Is that more about power efficiency, should I even care much for the rating? I'm looking to stick with Corsair. Thanks!
