Question Recommended Scale, DPI and Resolution for 21.5" monitors
Dec 10, 2020
30
Hello,
I'm looking for a monitor whose height (monitor + stand) could be adjusted to ~33 cm.
I'm considering the following monitors.
https://www.asus.com/Displays-Desktops/Monitors/Eye-Care/VA229QSB
It's highly important to me that Windows recommended/default scale (Settings -> Display Settings) would be 100% (96 DPI), and the recommended/default resolution would be 1920x1080.
Should that be the case with those 21.5" monitors?
Thank you.
Dec 10, 2020
30
@COLGeek,
Thank you so much. I appreciate it.
Either of them should be fine.
Allow me to make sure you're positive and referring to both Scale and Resolution.
(I once bought a monitor without testing it - the recommended Scale was 125%, and I just couldn't use it).
Personally, I would go with the Asus.
Thanks for that too.
Even though the AOC's response time is 4ms compared to Asus' 5ms?
