Recommneded power supply?
KentaZX
54
Hi, I've been having a debate on what kind of power supply Should I buy for my build that I'm working on. I haven't bought all the parts yet to make the computer, but my most concern was the power supply for these parts:
- GPU: Gigabyte GTX 770 4GB windforce OC version
-Processor: Intel i7 4770K @ 3.5GHz
- Ram: Cosair Vengence 16GB kit OR G.skill Trident X series 16GB kit
-cooling: Cosair H100i liquid cooling system
So what I want to know is, whats the best, safe, and reliable Power supply thats in 750W, and that can work with these parts above nicely without issues.
Hi - what's your budget & location?
80-150 $ for each part since I got the second most expensive part done. Which os the processor. And im in canada.
Hi again - Assuming you don't plan on adding another gtx770 for SLI, I'll suggest some PSU's that are more than sufficient for your system but less than 750w.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139005 Net $100 cad - Haswell ready
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151137 Net $104cad - gold eff- Haswell cert
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139031 Net $99 - semi mod - Haswell
and if i do decide to with 770 SLI? whats a good one then? the one that the other guy replied? because of the price in NCIX, im leaning to that one right now
Hi again - Yes, the XFX 850 is a good choice if you are going to SLI, and a fully modular 850 at that
price is an ex value. And, if you don't SLI, no harm done, the PSU still only pulls the power from
the wall your components require.
Alrighty im gonna go with that one then. Thanks to both of you :)
Enjoy!
