Recomondations for an AM3 system for under $1200?
arandomdumbass
5
Hello, I was wondering if anybody had and recomondations for an AM3 system I would like to build in May for under $1200.I plan on using it mainly for gaming. I would like it 2 have at least 3 pci express 2.0 and 2 pci slots as i plan on upgrading later. I plan on overclocking it as well. I'd prefer the parts come from Newegg. I have a 19" lcd. Thanks in advance.
JaredAudiophileGamer
163
Well if you've studied up and read that am3 + ddr3 isn't really the latest and greatest (only about a average 5% performance increase over ddr2 not too noticable) but if that is what you are bent on this is what i would suggest.
Asus M4A79T Deluxe + 4 Gigabyte Patriot Viper DDR3 1600 $267.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.176394
Amd Phenom II X3 720 + HIS Hightec 1 GB $366.99 (20.00 MIR)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.164891
HIS Hightec 1GB 4870 $259.99 (20.00) MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161265
Antec 300 $54.95
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=antec 300
OCZ ModXStream 700 Watt $94.99 (69.99) After MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341019
Western Digital Caviar 640 GB $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
LG DVD Sata Rom Combo Drive $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
$1149.88 Total Not including MIR And my opinion that can tackle most games of today high settings with pretty good aa settings on yor 19 inch
arandomdumbass
5
Reply to the animal
All right thanks il ask again in late april or early may. Btw when i said "I would like it 2 have at least 3 pci express 2.0 and 2 pci slots as i plan on upgrading later" i meant it didn't have to have exactly 3, i said at least. :)
Would this be good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223
Edit: Was typing when jared replied so i didnt see what you said till after i posted, thanks for the advice
Btw do you know when will the new south bridge come out?
163
hmm that does look like a pretty damn good board, but youd actually be paying more for buying that board, it doesnt look like it will be supporting any combo deals on the egg for awhile, and its brand new so it wait till some other guinea pigs buy it and review it :) and you might want to know that may / april is a really good time to buy,with the new phenom'(s) coming out and the new radeons prices on existing phenoms should drop some, but in my own unbiased opinion ;) i think that build would be the absolute bast bang for buck and could easily bout with crysis.
Edit: Heres a quote from some tech article. ("From what we can see from the SB800 details, AMD has a real chance of beating Intel's chipset offer. But until Q2 of 2009, when the SB800 is expected to be released, these are just pure speculations.")
Edit 2: LOL Heres the article. http://www.fudzilla.com/index.php?option=com_content&task=view&id=8228&Itemid=1
arandomdumbass
5
Thanks, and ive still got quite a while till i actualy order it, who knows what might come out(plus price reductions). :ange:
163
i hope they drop atleast 20 ;D im in the market to replace my motherboard and cpu, and im lookin at the asus m4a79 + phenom II x3 720 that combo is around 290 now.
TWO 4870's to drive a 19 inch monitor is overkill . Way overkill .
One 4870 is more than enough since I get 35 FPS in Crysis with e7300 @ 3.33 GHz/ 4850/2 gig of RAM on a 19 wide screen .
If the OP is definitely going to spend $1200 he should get a single 4870 AND a 22inch LCD
Well just a thought... for $1200 you can get an core i7 system...
CPU + Heatsink - Combo Price: $335.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.163999
Mobo - $249
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
HDD- $80
RAM - $89
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145220
CASE + PSU -Combo Price: $179.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.176939
GFX card - $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
Total - $1135
Unless there are very special reasons you want to go with AM3, I would suggest you go wit this build...
But seeing the probable purchase date in in May, then the P II 955 is coming in May...build ur PC after it releases...It will bring down the price of other CPUs as welll...
And nice info about SB800 from JaredAudio...like to see such gud competition between the green and the blue team...
jpdykes
594
gkay's build is very nice.
Wait until closer to the build date and look at options then.
I see no point in buying AM3 if you can work with i7.
Equally there is no need for anything more than 1x 4850 for 19" and a 4870 will eat most games at 22".
Suggests resurrecting the thread nearer to the build time.
Jeremy
bmuell
154
Combo the CPU with the Sapphire 4870 1GB , instead. They're both $15 off. Then get a Xigmatek Dark Knight. That's a really good mobo, but if you need to pinch a few more pennies, the MSI x58 Pro and Gigabyte x58 UD3R are both more than acceptable and are at least $50 cheaper.
Couldn't agree more.
How u came to $1.2k?
jcknouse
447
AMD AM3 build for gaming:
Case + PSU combo: $239.98 - $90.00 MIR = $149.98
ENERMAX Uber Chakra ECA5001B Black Aluminum / Steel ATX Full Tower Computer Case - Retail +
ENERMAX MODU82+ EMD625AWT 625W ATX12V Ver.2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE
Certified Modular Active PFC Power Supply - Retail
Mobo + memory combo: $263.98 - $20.00 MIR = $243.98
ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard - Retail +
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Dual Channel Kit Desktop Memory Model PVS34G1600ELK - Retail
CPU + GPU combo: $366.99 - $20.00 MIR = $346.99
HIS Hightech H487QT1GP Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16
HDCP Ready CrossFire Supported IceQ 4+ Turbo Video Card - Retail +
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX - Retail
OS + HDD combo: $199.98
Microsoft Windows Vista Ultimate SP1 64-bit for System Builders - OEM +
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
2nd HDD: $69.99
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
DVD + MCR/FDD combo: $41.98
Rosewill RCR-FD201 12-in-1 USB 2.0 3.5" Internal Card Reader w/ Floppy Drive - Retail +
LG 22X DVD±R DVD Burner Black IDE Model GH22NP20 - OEM
Total: $1,052.90 + any s/h
Not the best PSU or total setup, but just goes to show with even lots of frills that you can get under $1200.
