Ok, guys, so this problem's been pissing me off for months now. What happens is that whenever I record system audio using audacity (realtek drivers installed - the ones provided by Lenovo for my laptop), even if I use a lossless codec, the output audio is just <Mod Edit> I chose a test audio then I used WAV codec to record this audio again and the quality should be the same but it's not. Then if I take the output I just recorded and re-record it, the quality keeps getting worse. But as I said: I'M USING WAV!!! I should mention, though, that if I use the Windows Generic High definition audio driver, this problem doesn't happen, every single output has the same quality as expected, since the codec is WAV.
My laptop is a Lenovo Y720-15IKB and the realtek drivers are the ones provided by Lenovo (version: Realtek Audio_6.0.1.8555), as I said. Win10 21H2 latest version.
What could be happening? Does anybody know?
I'll provide samples of the audios and a print screen from the spectrogram. As for the spectrogram, the first image is the base test audio (audio 1.wav), the second one is the first re-recorded audio (I took the base and re-recorded it - audio 2.wav) and the third one is the re-recorded audio re-recorded again (audio 3.wav).
Samples + spectrogram image: https://www.mediafire.com/file/j8g1yevbu796edw/Samples.zip/file
