Recovery problem, need help
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My computer won't boot, do I need boot cd's?
I'm trying to use 8 cd's from hp for recovery. I don't care about saving
data, I'll start fresh. When the 8 cd's are done loading, I get the
message, "cannot
format user partition" "recovery cannot continue". When I start without the
cd's, I get the message, "NTLDR is missing" I'd really appreciate any help.
G
Guest
Guest
Thanks for your response, I'll try to answer your questions. I have a 514n hp
pavillion. I do F10 and when it asks I put the 8 cd's in, yes they're from
hp. I'm using them as recovery. I don't have a retail win XP disk.
When the 8 cd's are done loading, I get the message, "cannot format user
partition" "recovery cannot continue". When I try to start computer, I get
"R. C. White" wrote:
> Hi, Henry.
> As I said in the other Discussion Group where you posted this question...
> EIGHT! CDs? WinXP comes on just a single CD-ROM!
> HOW are you "trying to use 8 cd's"? Are you booting from one of those CDs?
> A full retail WinXP CD-ROM is bootable.
> It sounds like you should be asking HP about this problem, not Microsoft.
> If your WinXP is an OEM version customized by HP for their specific
> hardware, then HP is responsible for its support, not MS.
> Did you receive a full WinXP CD-ROM with your computer? Or only one or more
> "recovery" CDs? What is the specific model of your computer? If you tell
> us, someone here might recognize it and be able to give you some advice for
> it.
> RC
> R. C. White, CPA
> San Marcos, TX
> rc@corridor.net
> Microsoft Windows MVP
