Hello,
I come for help with my pc after weeks of attempts and research. This is my last try before I send it back for fixing.
About two month ago, my monitor started losing the signal while gaming, staying like that and forcing a manual reboot. Now I've seen this issue explained quite a lot but the answers are not always helpful, apart from a RMA. Which is what I did. So I sent back my faulty GTX 960 4GB, which it was, and got sent a GTX 1060 3GB, which was cool.
Fast forward to yesterday. I attach the 1060 and lo and behold! Same problem. After about 15 min to an hour of gaming, on multiple different games, monitor loses signal and doesn't find it again. Ever. I've tried with both a HDMI cable and a DVI cable. Same problem.
Another problem started to appear as well. The computer would suddenly restart while gaming. So I went and researched and it mentioned faulty PSU. I've also seen mention that the Corsair CX750M wasn't a good PSU at all. It's done it two times, but I haven't done anything since then as I am worried it might damage the rest. What PSU should I get if I where to replace this one? I'm looking for a really good one.
My question is are the two problems related? The GPU signal loss and the PSU restarts? Or am I wrong? I'm about to RMA both units unless you think its only one of the two. I'm hoping to test my GPU on a friend's PC. Could it be the build quality? The temps seem ok, I've been monitoring them and nothing is overheating.
Another final question, while I'm at it, is about the build itself. A friend helped me build it and as he gave me a screen with it, I kind of let him do his thing. Are their problems with it? It ran perfectly between May 2016 and January 2017. I ran Total War Warhammer on it, on Ultra with no problems. Things kind of happened suddenly.
My specs,
-EVGA GeForce GTX 1060 Gaming - 3 Go.
-EVGA GeForce GTX 960 SSC Gaming ACX 2.0 - 4 Go
-Intel Core i5-6600K (3.5 GHz)
-MSI Z170A SLI PLUS
-G.Skill RipJaws 4 Series Rouge 16 Go (2x 8 Go) DDR4 2666 MHz CL15
-Seagate Barracuda 7200.14 SATA 6Gb/s 1 To
-SanDisk SSD PLUS 120 Go
-Noctua NH-U12S
-Microsoft 10 64 bits Family
-Corsair CX750M 80PLUS Bronze
-iiyama ProLite E2480HS
My specs,
-MSI Z170A SLI PLUS
-Noctua NH-U12S
