Recycle Bin Problem.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I use winxp/sp2. When I delete email files from Outlook Express they do not
show in Recycle Bin. Same is true for other files. Recycle Bin Properties
does NOT have the "Do not move files to the Recycle Bin..." box checked. I
use "Freedom" anti-virus software from my ISP (Adelphia).
How do I persuade Recycle Bin to retain my deleted files until I want to
remove them permanently?
Peter.
G
Guest
Guest
Hi,
First, deleted email from Outlook Express does not use the Recycle Bin, it
goes to the deleted items folder in Outlook Express. Once removed from
there, then it is permanently gone.
Why the Recycle Bin is not receiving other deleted files is another issue.
Possibly a stuck <shift> key, as shift+delete will bypass the Recycle Bin.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"PVR" <peterv666@adelphia.net> wrote in message
news:ucGdnRCTmpL3gOXcRVn-gg@adelphia.com...
> Peter.
G
Guest
Guest
Oops, now I feel quite dumb re: deleted emails. However the other problem
still remains and the <shift> key works OK with other functions.
Thanks for your help.
Peter.
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:Oxg9GB9tEHA.3972@TK2MSFTNGP15.phx.gbl...
> Hi,
> Best of Luck,
>>not show in Recycle Bin. Same is true for other files. Recycle Bin
>>Properties does NOT have the "Do not move files to the Recycle Bin..." box
>>checked. I use "Freedom" anti-virus software from my ISP (Adelphia).
>> Peter.
G
Guest
Guest
You can ty this >>
http://www.kellys-korner-xp.com/xp_tweaks.htm
Read instructions at the top
64. Right hand side
Replace/Repair the Recycle Bin in Windows XP
Hope this helps. Let us know.
Wes
In news:5I-dnTmhdZCycOXcRVn-vg@adelphia.com,
PVR <peterv666@adelphia.net> hunted and pecked:
> problem still remains and the <shift> key works OK with other
> functions.
> Peter.
>> Hi,
>> Bin, it goes to the deleted items folder in Outlook Express. Once
>> removed from there, then it is permanently gone.
>> issue. Possibly a stuck <shift> key, as shift+delete will bypass the
>> Recycle Bin.
>> Best of Luck,
>>> they do not show in Recycle Bin. Same is true for other files.
>>> Recycle Bin Properties does NOT have the "Do not move files to the
>>> Recycle Bin..." box checked. I use "Freedom" anti-virus software
>>> want to remove them permanently?
>>> Peter.
G
Guest
Guest
Hi,
No reason to feel dumb. You didn't know so you asked. Let us know if Kelly's
fix helps.
Best of Luck,
news:5I-dnTmhdZCycOXcRVn-vg@adelphia.com...
> Peter.
>> Hi,
>> it goes to the deleted items folder in Outlook Express. Once removed from
>> Recycle Bin.
>> Best of Luck,
>>>box checked. I use "Freedom" anti-virus software from my ISP (Adelphia).
>>> Peter.
G
Guest
Guest
Short answer is "Yes, it worked, although I have only deleted one file so
far. Many thanks.
The long answer is that in order to Backup the registry I had to install
Backup from the WinXP disc which meant finding that disc, ad nauseum. But it
does work. Whoopee!
Peter.
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
news:ebSEFSEuEHA.3156@TK2MSFTNGP12.phx.gbl...
> You can ty this >>
> 64. Right hand side
> Wes
>> functions.
>> Peter.
>>> Hi,
>>> Recycle Bin.
>>> Best of Luck,
>>>> Peter.
G
Guest
Guest
I've been trying to figure why my Recycle Bin went bad. I had Norton System
Works installed on this computer. This included Norton's "Protected Recycle
Bin." I decided to uninstall System Works in favor of something else. Is it
possible this uninstallation caused the standard Recycle Bin to go bad?
Peter.
news:OA$dxDJuEHA.220@TK2MSFTNGP15.phx.gbl...
> Hi,
> Kelly's fix helps.
> Best of Luck,
>> Peter.
>>> Hi,
>>> Recycle Bin.
>>> Best of Luck,
>>>> Peter.
G
Guest
Guest
On Fri, 22 Oct 2004 08:36:30 -0600, "Wesley Vogel"
<123WVogel955@comcast.net> wrote:
>You can ty this >>
>64. Right hand side
Am I supposed to just add this file to my registry when prompted? Is
it safe?
G
Guest
Guest
Hi Teresa,
Yes you are and yes it is. Kelly has been developing and distributing these
for years. She tests everything on her own systems, and would never put up
anything malicious.
Best of Luck,
<teresa3480@cs.com> wrote in message
news:9alqq05nkr3fnhvqodpbrh9iu65q3frbuf@4ax.com...
>>You can ty this >>
>>64. Right hand side
> it safe?
G
Guest
Guest
On Wed, 1 Dec 2004 06:08:06 -0500, "Rick \"Nutcase\" Rogers"
<rick@mvps.org> wrote:
>Hi Teresa,
>anything malicious.
Thank you, Rick but the fix didn't do anything for me. Here's how I
did it finally!
My computer>C drive>folder options to show all system and hidden
files>select and delete Recycler(with the icon)>restart
