Recycled Bin damaged
carlosrafa
155
Hello! I have a problem. When I connect my 2tb Toshiba external Hard Disk drive to my PC and try to open or delete any directory or file, a window with the following message appears: Recycled Bin in G:\ is damaged. Would you empty the Recycle Bin for this drive? and with the yes and no buttons, but it doesn't work, and it doesn't allow edit, deleted the files. I would appreciate any help.
Hello Hlsgsz, thank you, but It doesn't work, after typing rd / s / q G: \ $ Recycle.bin in the window prompt as an administrator, I get:
"G: \ $ Recycle.bin \ s-1-5- ~ 3 \ desktop.ini - Access denied
G: \ $ Recycle.bin \ s-1-5- ~ 1 \ desktop.ini - Access denied "
then reboot the PC, but the problem persists. Help, please.
Hi,
The problem is back. the recycle bin of my external hard disk drive damaged when I tried to change some permissions of my external HDD, because it didn't open some files. I tried to solve with the previous procedure (rd /s /q F:\$Recycle.bin) in safe mode, but it doesn't work, and when I enter safe mode, a window pops up that says: "This application can not be opened, we can not open with the predefined administrator account, log in with another account and try again."
Please help.
Thanks
Latest posts
