Red and Blue are switched on my monitor.
Dan Roche
I'm borrowing two monitors from a friend for a few weeks while he's on holiday. I have two 680s in SLI and when I try and use the third screen, it inverts the red and blue, no matter which monitor I connect to it. It will only invert the third screen, the others do not change. The monitor is connected via DVI. Looking for either a hardware or software fix for this. Thanks!
Picture from the NVIDIA Control Panel: http://imgur.com/U40vjnH
I think either your port or cable may be broken, try using a different dvi cable if you have one
Thanks, I just tried removing the second monitor, but leaving the third (red/blue mixed) one plugged in. When I restarted my computer it was back to normal colours. I think this problem only occurs when I have three monitors connected.
I switched it to 5760x1080 and that somehow fixed the colour issue.
