Red and white cables
askara
246
i am trying to connect the power switch/led and reset 2 pin connector to the mother board, is the red wire the ground or white? or does it not matter?
it is asus z68 v LX, fractal design define r3 and antec trupower new 650w
The white wire is probably the ground. If there's a white wire on every other connector that you're plugging in, then that's definitely the ground.
