So this is my second build, first water cooling, and the CPU led was on as soon as I turned it on for the first time, won't boot or go to bios just a black screen. So thinking I might've bent some pins or something I took everything out and checked for bent pins. Nope. Did a bench test with just the stock cooler and one stick of ram and...everything was fine. Got to bios, got a boot device led but I didn't have any sata cables hooked up so that was expected. Put everything back in, bled my loop, turned it on, and the light comes on again! I tried hooking it up to a different power supply and using only one stick of ram just like on my bench, and still nothing. The only difference between now and my bench test is the waterblock I have on the CPU. I tried loosening it a little, nothing. Any help please?
Pc specs
CPU: i5-4670k
Motherboard: asus z87 plus
Ram: corsair xms ddr3 1600
Psu: seasonic x850 (now hooked up to corsair tx750 from my bench test)
Gpu: gtx 770
Cooling: custom loop with xspc raystorm block
Pc specs
CPU: i5-4670k
Gpu: gtx 770
