I just built my first pc and it’s not booting. Everything is plugged in correctly and all the fans are spinning.
When I first turn the psu on, the mother board lights flash for a little bit and the only light on is the Red CPU led.
I’ve tried everything. Reset the CMOS, took out the CMOS battery and put is back in, tried different ram slots and also with one ram, and even checked the cpu for bent pins.
If the Mobo was dead then wouldn’t the case fans and cpu not work?
Also I can turn my pc on from the front panel button but can’t turn it off when I hold or press it.
Specs:
Everything is new but the GPU which is used but is also fairly new
Specs:
Ryzen 5 2600
16gb 2x8 3000mhz
RX 580
B450 Aorus Pro WiFi
Corsair 650w psu
