Archived from groups: alt.comp.periphs.dcameras (
More info?)
If you provide some extra light to balance the brightness of the LED, you
should be able to get a good exposure of the LED lit and the surrounding
components.
The trick is to light with a utility light and vary the distance of the
light from the object. If that camera has a manual shutter and aperture
setting, use that instead of Auto.
For the color balance, if you use a tungsten light (household bulb), set the
White Balance of the camera to Tungsten. Then the colors will be more
realistic.
CSM1
http://www.carlmcmillan.com
"Michael" <newszz10@yahoo.com> wrote in message
news:ZoidnQLTkd5dj2DfRVn-qg@comcast.com...
> Ok thanks....makes sense.....do you think I'd have a better photo also if
I
> kept dimming the leds until it looks right?
> So a filter is of no benefit at all right?
> I'd like the led's to be truer red also.
> "CSM1" <nomoremail@nomail.com> wrote in message
> news:GP7Le.536$A%3.530@newssvr33.news.prodigy.com...
> > "Chuck" <chuckk2@cox.net> wrote in message
> > news:dN5Le.418$ct5.211@fed1read04...
> >> The blurred problem is that the camera is focused on the display face,
> >> not
> >> the Leds inside. Manual focus may be your only answer if you cannot
stop
> >> down the lens to get a greater depth of field.
> >> news:2q-dnRuRdNVuA2HfRVn-iQ@comcast.com...
> >>> I have something that I'm trying to get a photo of and it has a small
> >>> red
> >>> led display on it.
> >>> When I just take a normal set up photo with my D450Z it makes the
> >>> display
> >>> blurry and slightly off color.
> >>> Everything is well lighted but was wondering....should I be using some
> >> sort
> >>> of filter? or?
> >>> If so, what color?
> >>> THANKS very much for any help.
> > Or maybe you need to be in the Macro mode. If the object is small and
you
> > are placing the camera very close.
> > See Page 82, 106, 110 and 202 of your Reference manual.
http://www.olympusamerica.com/files/D450_manual.pdf
> > CSM1
