[SOLVED] Red light "DRAM_LED" on motherboard
Mar 23, 2020
5 year old system... turn my pc on this morning and my monitors won't display anything.
There is a solid red light on "DRAM_LED". The motherboard is a Asus Z170-AR.
I tried rearranging the ram and using just one stick. After pressing the "MemOK!" button, the red light blinks a few times and then goes away, there is then a solid red light on "BOOT_DEVICE_LED".
Any suggestions?
SPECS:
CPU: Intel Core i7 6700K
CPU Cooler: Corsair H100i GTX
Motherboard: Asus Z170-AR
RAM: 2 xKingston HyperX 16GB DDR4
GPU: Galax GTX 1070
SSD: Samsung 850 EVO 250GB
HDD: Tobisha 3TB
PSU: EVGA SuperNOVA G2 750 Gold
OS: Windows 10 Home
Nov 3, 2020
73
4
45
Easy method is to remove cmos battery for 5min to 10 min.. Unplug before psu from power
While the battery is disconnected put the tip of a screwdriver and touch both of the pins to connect them (shorting the pins) for like 5-10 seconds, more chance of success, and before trying to start your pc try disconnecting everything except cpu, gpu, 1 ram stick and monitor, and if it boots connect 1 by 1 to see when it fails
