Hi all,
Happy New year! I'm not sure if this is the right place to post this.
here goes:
I'm trying to install my new motherboard with my new case. I noticed that this new case doesn't have those red washers (a.k.a Fiber washer) with it. I thought it was just wasn't shipped or something... but when I called them (manufacturer), they said that it really doesn't have it. However, it still has those METAL standoffs instead of plastic. I was expecting plastic because red fiber washers were not included. Now, I did some little research about these "red washers" and I got so confused and interested at the same time.
I found out that there was a long debate about using this red fiber washer or not. Some people say that these "red washers" is a MUST for BOTH sides (1 on top and 1 underneath the mobo for each screw). Some of them say that these red washers will not be in the package if it wasn't important (true).
Some people say that these Red Washers are useless (just for tightening purposes or for non-metallic holes in the mobo). They also say that you should just directly screw the bolts without the use of any washer. They say that the purpose for that is grounding stuff (which I think is very important).
They also said that those "metallic holes" in the motherboard was put there for this grounding purposes. Motherboard manufacturers will not put metal holes if it will just be insulated by red washers. They should have put a non-insulating material instead (good point too).
What is your standpoint regarding this matter and please explain =)
EDIT: new mobo package and/or casing did not have those red washers
Thank you so much.
here goes:
Thank you so much.
I have lots.
