Question Redfall Performance Help - PC
Lushern1309
164
15
4,615
Hi Guys, anyone playing Redfall on PC, any tips, settings to get the game running better, massive random frame drops, drops to the high 20s sometimes, contrary to reviews I'm actually enjoying the game but the performance spoils the experience, my specs are in sig, I think I have enough to run the game at medium, 1080p with DLSS if needed
I wouldn't be too sure of that, especially since many are saying it's unoptimized AND your spec is low. You CPU is right at min reqs, but the real problem is your GPU is just below min reqs.
Redfall Min Reqs
That doesn't exactly scream Med settings. The short answer, is if you're dropping to the 20s on Med, you need to put them on Low AND use DLSS since your GPU is below min reqs. Or maybe wait for a patch if that doesn't look/perform good enough.
Redfall Min Reqs
Thanks for the reply, will just wait and hope the game gets patched, as in game usage doesn't point to any of my components being anywhere close to maxed out
