[SOLVED] Redragon K586RGB BRAHMA: typing not registered ?
kyubey
9
For example when i type something like, once in a while it turned into
this
Fo example when i type something like, once in a while it tured into
I wasn't even typing at full speed.... it's on very casual speed.
It's also randomly happened on any key, so it's not a simple 'a' is broken.
Doesn't even happen that much (like 10 sentence missing 3 alphabet level), but when it does....... it's annoying.
tried taking key caps off and cleaning any dust/hair/etc that might be interfering with the keys.
I had to take the keycaps off my Corsair kb a few days ago as a few of my keys were doing the same things.
  • shake keyboard around,
  • blow it with compressed air.
  • I use paint brushes to clean mine
Reactions: kyubey
