Hi friends, I would like to change my PC Case to reduce the fans noise.
I currently have:
Zalman CNPS9700NT CPU Fan
Asus P5N-T-DX Motherboard
Thermaltake Armor VA8000BWS
OCZ 700W Gamer XStream SLI (OCZ700GXSSLI)
Intel Q9450 2.66Ghz
I try to reduce the fan speeds but the lowest i can get is 2500 RPM for the CPU.
My Zalman cpu fan make WAY too much noise.
I need to find a new PC case that will cut by half my pc noise.
thank you all!
I currently have:
Intel Q9450 2.66Ghz
thank you all!
