Recently I have built a rig for mining for my friend. The GPU he has is Zotac 3080 trinity. However, the heat generated is so high esp the Junction temp of the Vram. I did not do anything or overclock the Vram, just let it mine for 15 mins, the junction temp went from 39c up to 110c. I tried using MSI burner to try to adjust the power and temp limit, but it did not really solve the problem. However, one question that I have is I tried manually adjusting or setting the fan to 70 to 80 percents. If I do not mine, then the fan will run constantly almost but when I mined with phoenixminer, then the fan stopped spinning. In addition, even if I tried to adjust the fan to 70% but when it runs it just adjusted itself to 35 to 50 percent and if I let it run auto, then sometimes it never runs. I am just wondering if this is normal? Is there anyway that I could adjust the fan to run 70% CONSTANTLY when mining?
I mean 110c is no no for mining even I did not do anything or overclock the vram.
