Hi,
QUERY
I have just received my 3Tb WD Passport Ultra model and I would like to be very clear about reformatting in order to have fast data speeds.
In addition I would also like to know if your answer is the same for my 2Tb Ultra models.
PC INFO
I use Windows 10 on a 2 year old Dell i7 computer with 20Gb RAM. USB3 sockets used.
ISSUE DETAILS
My equipment is used to play Apple movies on my PC using iTunes.
The .m4v files are held on an external WD Passport.
Most of the time replaying the films does not cause any buffering, however, I wondered whether reformatting differently might cause the the .m4v files to be retrieved at a higher speed and lower any chance of buffering.
WHAT I'VE DONE
To try and test this, I have (FULLY) reformatted an earlier My Passport Ultra 2TB using NTFS still as a single partition but with 8192 allocation units instead of the default 4096.
My thoughts were that this might help the rate of both storage and retrieval of large files, albeit at the expense of wasting some space.
QUESTIONS
1. Is my change to 8192 AU on the 2Tb model a 'sensible move' in order to increase read speed, or is there a better way? Alternatively, am I wasting my time?
2. Is it safe to carry out reformatting the new 3Tb My Passport in exactly the same way as I did on the 2Tb model - in order to increase read speed?
3. Can I 'security erase' the new 3Tb My Passport without any issues, and then reformat it using the usual Disk management in the Administrative tools of Windows 10 Control Panel?
I am aware that there are such things as GPT etc, but I don't know enough about this and would appreciate guidance. After all, I don't want to brick my new 3Tb unit.
Thanks in advance for any knowledgeable expert advice here!.
Blobbyflob
QUERY
PC INFO
ISSUE DETAILS
WHAT I'VE DONE
QUESTIONS
Blobbyflob
