Refresh Rate help me please
8bitpwnage
292
So I recently ordered a monitor for gaming. This is the monitor in question.
https://www.asus.com/Monitors/VX239H/
I want a refresh rate of 100hz-120hz if possible. The problem is it only has 2 HDMI Ports and a VGA Port. Will a Display Port-HDMI adapter do the trick? The resolution I will be playing at will be 1920x1080 if you guys want to know.
I'm sorry to say that monitor you linked to doesn't support refresh rates that high. At 1080p the refresh rate supported is 60Hz.
Have a look at page 3-8 of the User Guide.
You're right. I guess I'll have to bear 60hz but it's all good. Anyways, can you recommend 120hz monitors that are between 200-400$ and has a response time of 5ms and below? Thanks for the help though :)
