What's up with the ASUS VG245H? If I try to set a custom refresh rate higher than 75hz, I lose connection to the hdmi output and the monitor refuses to connect until I set it back to 75hz. What kind of sorcery is this?
Is there any way to work around it and let me go higher than 75hz?
Monitor is advertised to run at 75hz but then there's an another model which has 144hz but looks identical to the one I have so it was probably done on purpose with a software.
I got a benq monitor and i'm able to overclock it to whichever number I want so it's pretty sad that asus put a restriction on their monitor.
