Refresh Rate Solution Required
abul.wahab.3
12
Hello, guys m not too much into the tech kinda guy. but i have a question. i have a gaming laptop but the refresh rate of my laptop is only 60Hz. now the question is that if i connect my laptop with a lcd monitor capable of 144Hz or something with HDMI cable as my laptop doesnt have DVI port, will i be able to play the game at 144Hz or will it be capped on the same fps which is 60 ... please let me know. cz if it wont run in 144Hz, no use buying new lcd monitor. What is the possibility by which i can play game at 144 Hz or even stale 100FPS or something..
i have GTX 960M 4GB graphic card with 12 GB ram and i5 proc .... will it work? cz i play Battlefield 1 and Rainbow Six Seige. at 60 FPs ... i want to increase it .. what can i do if i wanna have higher fps?
And model name of the laptop?
Generally - with Display Port connection there wouldn't be any problems with high refresh modes.
With HDMI - most likely you'll be limited to 60Hz operation.
ok i will tell the specification shortly. cz i dont have my laptop with me right now. then you can tell me exactly what i can do to hit 144 or 120 fps in games.
thanks alot for such a quick response guy .ill post the details shortly
https://support.hp.com/si-en/document/c04727437
here guys ... here you can check all the details of the laptop m using right now ... please advice me the solution according to my machine .. my ram is 12GB .. this one shows 8 GB . i upgraded .. please and let me know .... very much appreciated ..
MERGED QUESTION
Question from abul.wahab.3 : "FPS Fix Issue"
guys i found the solution for it. i just serviced my laptop and i used Arctic Silver 5 thermal compound paste for the processor and the GPU ... and my games are working just fine now. thanks for the support tho :)
